Sponsored by: CARiD
1990 Toyota Pickup DLX Surging Issue
Old Jan 20, 2017 | 03:27 PM
scizzors's Avatar
I have a 1990 Toyota Pickup Deluxe, I recently ran it about a mile without the oil cap on, and noticed oil splattered all over the engine,
(The truck ran fine, filled oil back up drove it for the last few weeks, and I finally got a day off to clean the engine.
22re engine btw - about 150k miles on it.
So i decided to wash the engine, well it starts, and idles great.
I will try accelerate with a half throttle, and it surges.
I can go 1st gear, slowly, then go to second gear, n third, but if i try to go more than half throttle it surges.
I was thinkin water/condensation on the distributor, so i took that off n cleaned the inside with a dry ppaer twoels
any other ideas?
Old Jan 21, 2017 | 06:49 AM
Co_94_PU's Avatar
Throttle sensor is very close to the oil cap. It may have gotten oil soaked through the seals. May have gotten cleaner inside. Cleaner might have forced a mix of both inside.
In no particular order. Check for vacuum leaks, failed sensors, and air in the coolant system.
Old Jan 21, 2017 | 06:51 AM
Co_94_PU's Avatar
PS describe the surge, are the rpm surging up or downwards.
