Sponsored by: CARiD
1987 Toyota Pickup Overdrive light questions
Old May 16, 2017 | 07:30 AM
ljknudtson's Avatar
I bought a 1987 Toyota pickup truck, auto trans.
Soon there after, I proceeded to remove the center portion of the dashboard, so I could insert a 6" speaker there for quality surround sound.
In that process, I had to remove the "overdrive" light that indicates if I'm in overdrive mode, or not.
Since then, it doesn't seem like I can switch in and out of overdrive.
Wondering a couple things;
One - Does the light need to be apart of the ciruit in order for overdrive to work
Two - Can I find replacements for the light?
Three - Is there a way to close the circuit without replacing the light?
Lee
Attached Thumbnails 1987 Toyota Pickup Overdrive light questions-img_0482-1-.jpg   1987 Toyota Pickup Overdrive light questions-img_0481-1-.jpg
Old May 16, 2017 | 02:15 PM
Co_94_PU's Avatar
More likely bad wiring, like those electrical nuts or similar.
My bulb is out and has no effect on shift selector.
