1985 Toyota Diesel Pickup Bed Removal?
Subscribe
May 25, 2012 | 07:23 AM
Just curious how similar the bed removal process is to the 22re.
Remove taillights / wires
Remove screws for diesel piping
Remove 4 bolts on the edges of the bed(?)
Any recommendations if it's rusted? Penetrating oil spray, heat up the bolts?
Thanks!
Reply 0
May 25, 2012 | 11:58 AM
Shouldn't be very different, I'd think same frame, tank, lights, etc. Man, I wish I had a diesel.
Reply 0
May 25, 2012 | 12:18 PM
Soak the bolts in PB Blaster a few days before and take a wire brush and get the threads as clean as possible. Then hopefully you got a impact wrench and set it on the highest settings. Mine was a pain to get off.
If using wrenchs, here is what I have done in the past. Lock them together and keep them flush witheach other and you can get alot of leverage. I have broken bed bolts using this trick.
Reply 0
May 25, 2012 | 12:52 PM
or just cut of with a torch since they most likely will be a pain
Reply 0
May 25, 2012 | 03:25 PM
Quote: Soak the bolts in PB Blaster a few days before and take a wire brush and get the threads as clean as possible. Then hopefully you got a impact wrench and set it on the highest settings. Mine was a pain to get off.
Haha! I love the box wrench cheater. I still remember the day my grandfather showed me how to do that.
Reply 0
May 29, 2012 | 02:30 PM
Lol..It does come in handy. Not everyone knows about it and it has helped numerous times over the years. I have gotten enough torque on one to bust a bolt and when it let loose, I wound up on my rear, but hey it works.
Reply 0
