WANTED - wheel/tire as spare for 1994 4x4
I just picked up a 1994 standard cab 4x4 with 31x10.5x15s.
No spare was included.
Anyone know of a suitable aftermarket cheapie steel wheel that will fit over the hub?
Or anyone (close to Kentucky) have a spare they want to sell?
Thanks
Jw
Thanks
Jw
To add some info, most 6 lug rims are the same bolt pattern, just have to make sure it's either an aftermarket rim, or it's from a toyota/large hub pickup. The newer (like 90s+) chevy rims have the hub hole too small. If you was closer, I have plenty of rims around.
Thanks.
I ended up picking up a ProComp PCW97-5883 wheel that somewhat matches what is on the truck.
It was on sale and free shipping:
https://www.4wheelparts.com/Wheels/Pro-Comp-Series-97-15x8-Wheel-with-6-on-5-5-Bolt-Pattern-Gloss-Black-97-5883.aspx?t_c=11&t_s=535&t_pt=101508&t_pn=PCW97-5883
I went so far as to call ProComp to verify with one of their tech support guys that the center bore was large enough.
He confirmed that it would fit the 4x4 hub from 1994.
Let's hope he is correct.
I'll update once I have it and test fit it.
thanks again
jw
thanks again
jw
No problem, pretty sure the center bore should be fine. Seems most aftermarket companies make the rims fit as many machines as possible.
Stock rims are 7in wide, but shouldn't effect too much. If you have the exact same tire on all 5 rims, the 8in one will be a tiny bit shorter. It will be fine for a spare.
drpdmazda
Jul 22, 2006 05:12 AM
Ilovemountains
Jun 17, 2004 06:00 PM
