Spacer Lift
Old Apr 3, 2007 | 07:51 PM
Bryan06runner's Avatar
Spacer Lift
I would assume that when you install a front spacer lift and preload the springs you get a stiffer ride. Is it way more stiff or not that bad? I just got the Daystar 2.5" front lift but am worried that I will have a terrible rough ride. Thanks.
Old Apr 4, 2007 | 02:50 AM
Expat's Avatar
You will not notice a difference (well maybe if your terribly anal LOL). Before my OME setup, I ran the Daystar spacers with very little observable difference in ride quality. Because your center of gravity is higher you might notice a bit more lean in corners. If you have XREAS then this too will mitigate to some extent the lean around corners.
Don't sweat it.
Old Apr 4, 2007 | 10:00 AM
Thanks for the info!
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
