Spacer Lift
Spacer Lift
I would assume that when you install a front spacer lift and preload the springs you get a stiffer ride. Is it way more stiff or not that bad? I just got the Daystar 2.5" front lift but am worried that I will have a terrible rough ride. Thanks.
You will not notice a difference (well maybe if your terribly anal LOL). Before my OME setup, I ran the Daystar spacers with very little observable difference in ride quality. Because your center of gravity is higher you might notice a bit more lean in corners. If you have XREAS then this too will mitigate to some extent the lean around corners.
Don't sweat it.
Don't sweat it.
1uzRunner
63
Nov 10, 2018 03:58 PM
choppe777
May 16, 2016 08:00 AM
