Help with 3" lift on 07 4runner Sport
Old Jul 11, 2008 | 08:17 PM
defcon47's Avatar
Hi Guys,
I'm new here and have been digging around for some help with no luck. I hope someone can chime in and help me here.
I have an 07 4runner 4wd Sport with XREAS. I ordered the 3" Toytech lift and was anticipating getting the Dick Cepek DC1 rims. Today I found out at the 11th hour that the 17x9 rims are going to give me a problem so I have to find a new rim of 17x8 or 17x8.5.
My heart was set on those DC1's and the shop is telling me that they dont recommend putting a 9" width on there.
Has anyone been able to make a 17x9 fit on a 3" lift? Do I need some spacers or something?
Please help. I need to get lifted and hit the beach!
Thanks!
Old Jul 11, 2008 | 10:41 PM
tempsho's Avatar
If your going to hit the beach, put on water wings and some suntan lotion and your set!!!
As far as the lift goes, I think 2" or 2.5" is the most you can go without having to remove the XREAS. Do and few searches and see what that brings up, I know its been discussed before. What size of tire are you going to run with the 17x9's? Slight trimming of the liner might be required regardless.
Old Jul 11, 2008 | 11:19 PM
defcon47's Avatar
Based on some of the reviews and such I've come across I was planning on a 275/70/17, either the Mickey ATZ or the Nitto Grappler. I haven't decided.
I just need to get the rim size figured out so I can order something this weekend.... That's my issue, I'm being told by the shop that the 17x9 will give me problems and I need to go with 17x8. Anyone know if the 17x9 is doable with the 3" lift I already ordered?
Old Jul 12, 2008 | 01:06 AM
tempsho's Avatar
Depends on the backspacing of the rim. In most cases, a 17x9 rim will stick out 1" farther than a 17x8. Do you have the backspacing specs of the rim? If not, a 17x8 is a safer bet. Spacers (if your refering to the rims in your first post) will only push the rim out farther, making the situation worse.
Old Jul 12, 2008 | 01:19 AM
defcon47's Avatar
These are the rims I was set on getting.
http://www.dickcepek.com/DC1_Black.html
Any idea which one I would need. I read somewhere else the bolt pattern of my truck is 6x139.
Old Jul 12, 2008 | 01:48 AM
CC_yota's Avatar
Try http://www.toyota-4runner.org/. There are a lot of 4th gen owners over they're and they'll probably be better suited to your questions.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
