Changing tire size - spare too?
Old Dec 31, 2006 | 10:43 AM
I am looking to go from 265/65R17 to 265/70R17. Is it mandatory to buy a new spare tire also? Can you run 3 of the 265/70 and 1 of the 265/65 if you get a flat?
Thanks.
Old Dec 31, 2006 | 10:45 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
search around, there are huge debates on this. some will say absolutely no, some will say it doesn't matter if its just a temporary solution. ideally you should have a full size spare but with such a small difference in your sizes, you should be fine. if you had to run it, the front would be the best if you're driving around in 2wd.
Old Dec 31, 2006 | 10:46 AM
Hayes's Avatar
You can but even that difference can cause drivetrain problems if used for too long...
Recommendation: buy 5 tires to match.
djpg2000
Nov 11, 2020 04:56 AM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
