another 4th gen. lift in progress soon
Old Mar 27, 2004 | 06:38 PM
  #181
r0cky's Avatar
Where would I buy new cotter pins?
Old Mar 27, 2004 | 06:46 PM
  #182
Good Times's Avatar
You can try Autozone. Not sure if they might have it but I know cotter pins are pretty generic. I know someone has to have it beside the Toyota Parts Department.
Old Mar 27, 2004 | 07:15 PM
  #183
r0cky's Avatar
After I get all the parts installed, will the torn ball joint boot be alright to drive with, I mean ... to drive to a shop with so I can get it replaced? Crap. How do I know if I need to replace more than just the boot?
(i ask because i hit the bolt with a hammer and now I read that if you do that, you'll have to replace the entire thing)
Old Mar 27, 2004 | 08:42 PM
  #184
Good Times's Avatar
The ball joint boots are not critical as it just happened. You should be able to drive it for awhile before you gotta fix it.
As for using the hammer to break something.... The arms itself are pretty strong that you won't be breaking anything.
You should be able to do the lift w/o replacing the boot. You can do that some other time. I would still look for the cotter pin though.
Old Mar 27, 2004 | 08:45 PM
  #185
r0cky's Avatar
I smacked the crap out of the outer tie rod end bolt with a hammer ... arg.
Yeah, I figure I'll do the lift, and then take it to get it aligned, and have them replace the boot and make sure I didn't screw anything else up. I'll look for a cotter pin in the meantime, thank you.
From here on out, I won't be touching the balljoints or the tie rod end. Yesterday you mentioned that I should not let the rubber piece pinch ... which rubber piece were you referring to??
Old Mar 27, 2004 | 08:51 PM
  #186
Good Times's Avatar
rubber piece on the top. Check my previous post on the image I copied from you and made a big red circle
Old Mar 27, 2004 | 08:56 PM
  #187
r0cky's Avatar
Oh, right, well ... that piece is a-ok so far. After not being able to have any success with the tie rod end balljoint, I decided not to pry on the upper balljoint! First smart decision of the process! hehe. As I researched the boards, a lot of posts were made saying that if you hit that bolt (the one on the outer tie rod end balljoint) you'd have to replace the entire big piece. Bah. Well ... guess I will just wake up early and get started again. Hopefully this time with more success ... I'm sure once I get one side at the front done, the rest won't be as hard because I'll know better what to do. Wish me luck!
Old Mar 27, 2004 | 09:02 PM
  #188
bulldog-yota's Avatar
Originally Posted by Biff
You're right its like a 5 hour drive. Its a little bit to much for me.
no prob. it's a long way to drive.
Old Mar 27, 2004 | 09:07 PM
  #189
Well good luck for tomorrow!!!!! good decision to take a break first.
Old Mar 27, 2004 | 09:10 PM
  #190
Lance & the other guys,
Thanks a lot for all your help, I'm certianly learning a lot so far.
4route sorry you had to be the test rabbit
Old Mar 27, 2004 | 11:17 PM
  #191
r0cky's Avatar
One last question before I start in the morning:
Is it okay for me to loosen the top/center nut on the strut shaft just enough to break the bolt? I know it is under pressure, but I also know it will be impossible to break when it is loose from the assembly. So should I loosen it just a tiny bit before compressing the springs and removing the whole assembly ... or should I compress the coil and then loosen the bolt while it is still in the tower?
Old Mar 27, 2004 | 11:24 PM
  #192
Good Times's Avatar
if u compress the coil, the top center will be easy to remove
Old Mar 28, 2004 | 08:38 AM
  #193
r0cky's Avatar
Alright, well, I'll compress it first, but I was just concerned about being able to loosen the bolt, since all the other bolts on the truck have been incredibly difficult to loosen.
Old Mar 30, 2004 | 05:01 PM
  #194
r0cky's Avatar
This is bull. So I have the strut bottom out toward the front of the vehicle, but I still cannot get to it enough to compress it. Have any of you actually done this before? If so ... please help me here, I have been working at this for a week and I need some help, please ... I know some of you have done this and have to know what I am talking about so please, just take two seconds and give me some help here.
I have XREAS, I have gotten the strut bottom out and loose, but the strut is so angled and tight that it's almost impossible to get these Craftsman compressors on safely/straight. Do I pull the top of the strut under the a-arm somehow? What do I do to get it in a position to compress the coils ... how was it set up when you guys did it?
Please help me.
Old Mar 30, 2004 | 05:23 PM
  #195
Have you removed the upper bolts (3 bolts) that hold the upper end of the strut assembly to the body? You should be able to get to the strut then, shouldn't you? Maybe post pic.
Old Mar 30, 2004 | 05:29 PM
  #196
Good Times's Avatar
Indeed, photos will help here. Gotta see what we're up against so we can help ya out
Old Mar 30, 2004 | 05:37 PM
  #197
r0cky's Avatar
yes, of course I have removed the top three bolts. the strut is loose, but i can't pull the top of it under the a-arm toward the front (like you said i should, lance).
i know other people have done this -- i wish they would respond too.
Old Mar 30, 2004 | 05:40 PM
  #198
Good Times's Avatar
It's the center bolt that hanging you up right? Is it hanging up about 1/2 inch or so? I remember being able to clear the 3 bolts but the center one was the hang up for me too.
Just making sure we're on the same page here.
Old Mar 30, 2004 | 05:45 PM
  #199
r0cky's Avatar
well ... the center bolt is hanging up less than 1/2 inch ...
but it's more than that ... didn't you tell me that i should be able to pull the whole strut/coil UNDER the arm and toward the front of the truck?
Old Mar 30, 2004 | 05:49 PM
  #200
Good Times's Avatar
recap: I'm pretty sure you took the swaybar off but never hurts to ask again anyway
As for the 1/2" part, that's the part that'll be a pita. You'd have to do some creative moving of the assembly to get it out. How about pushing the shock up and pulling the bottom out to the front and then out? Anotherwards, the other way around instead from the bottom.
Running out of ideas but I know we'll get it.
