1GR-FE Upper Oil Pan Removal
Old Jul 28, 2022 | 05:51 PM
foampile's Avatar
Simple question: Is it possible to remove the upper oil pan on 1GR-FE (Tacoma, FJ Cruiser etc) with the bottom one still attached or does the bottom one need to come off first? The Haynes manual says take the bottom off first but I don't fully trust Haynes, it often advises to do things that are not really necessary.
Old Jul 7, 2025 | 02:03 PM
Yota$lut's Avatar
You need to remove the lower oil pan to access two 12mm bolts inside to remove the upper oil pan,
k-e-e-p-e-r
Jul 23, 2016 08:11 PM
goinggoat
Dec 12, 2013 10:15 AM
4Hummer
12
Nov 11, 2011 08:23 AM
Schroby
Sep 29, 2009 04:50 AM
