05 Tacoma cranks but won't turn over
Old Aug 7, 2021 | 11:05 PM
Elkslayer121678's Avatar
05 Tacoma cranks but won't turn over. Ran fine then one day I didn't know if I had enough gas to get to the gas station so I grab gas can out of the garage and added a little fuel, well I got about three blocks away and it just died it won't start it cranks but won't turn over!! I replaced the fuel pump that's not the problem what do I do? Please any suggestions is very appreciated! Thanks
Old Aug 8, 2021 | 03:09 AM
wyoming9's Avatar
Red face
You mean it cranks(turns over) but does not start!
What tests did you do to before replacing the fuel pump ? Test the pump you removed??
Where you having any problems before this ?
Is the Check Engine Light on and Have you pulled the codes
****Are you 100% positive just what was in the gas can?****How long it might have been in there.
Just How much was a little ?? Either you ran out of gas or what you dumped in was enough to contaminate the fuel in the tank.
Did you clog the fuel filter ruin the injectors foul the spark plugs ??
Then it is possible one of those things that just failed not related to anything else.
GOOD LUCK!!
Old Aug 8, 2021 | 02:31 PM
Yes cranks but won't start. No did not act funny but just found out my dip˟˟˟˟ son I guess needed gas for his car so he took what gas that was in the gas can and he didn't want me to notice so he said he left a little bit in the bottom then filled the rest up with water.!! He just confessed 15 minutes ago!! What did he F up?besides him not having his own car for a while
Old Aug 8, 2021 | 02:33 PM
About why new pump
The reason why I put a new fuel pump in it is because my so-called uncle that thinks he's a mechanic knows everything said that's what it was so that's what he told my dad and my dad said to put a new fuel pump in it so he went and bought a new fuel pump and I put it in that's why I put a new fuel pump in it so now I have two people that are on my ˟˟˟˟ list my son and my stupid ass uncle
Old Aug 8, 2021 | 03:06 PM
wyoming9's Avatar
Red face
We have all done dumb stunts it could have been worse no one was injured .
It might help the youngin to learn a lesson cleaning the underside of the Truck with a Tooth brush
The fuel filter is full of water With luck the filter has caught all of it.
Change the filter you might want to pull the plugs look at them.
Just how much water did you add to the tank?
The ethanol in the gas should absorb the water if possible get as much fresh gas as possible
Old Aug 8, 2021 | 03:14 PM
I've been reading that the filter is on the pump in the tank which the pump is brand new. He said there was about a cup and a half of gas in the 5 gallon can. When I supposedly was putting gas in my truck with that same can it was full
Old Aug 11, 2021 | 04:56 AM
wyoming9's Avatar
Red face
Any Luck with this ? When you changed the pump you never took notice of the water in the tank?
5 gallons of water after that has been removed as best you can a few bottles of gas dry plus fresh ethanol gas should take care of most of the water .
Looking at the spark plugs would be my next step .
Ashlei Hardy
Feb 8, 2014 08:59 PM
Pablo.gyds03
Jun 25, 2013 05:16 PM
Crawler2794
Jun 22, 2012 02:12 PM
stockyotadriver
Jun 29, 2008 08:03 AM
calrockx
13
Mar 20, 2005 04:14 PM
