Wrong spindle bushing??
Old Feb 15, 2011 | 09:04 AM
squampton's Avatar
Question Wrong inner spindle bushing??
I'm about to replace the driver side inner and outer spindle bushings on my 1990 4runner and I went to the dealership and asked them if they had any inner and outer spindle bushings. They special ordered some in for me and now I have this feeling the inner ones aren't the right ones. The inner one that I got looks like the 2 brass bushings in the 2nd picture in jimrockford's write up. part number: 90381-32001 https://www.yotatech.com/~corey/tech...imrockford.htm
I just want to the replace inner brass bushing and I DON'T want to do the needle bearing/bushing conversion like jimrockford. The old inner bushing shown in step 15 in jimrockford's write-up looks alot different than the one I got from the dealership.
So will the inner bushing that I bought still work without he needle bearing?
Old Feb 15, 2011 | 09:16 AM
TNRabbit's Avatar
As long as they are the bushings & not the bearings. The bushing should have one in the rear of the spindle & one at the front, so four pieces for both sides.
Old Feb 15, 2011 | 02:48 PM
squampton's Avatar
I'm just doing one side for now and I got the inner and outer bushing but I wasn't quite sure if I got the right inner bushing because the old inner bushing looks quite a bit different than the new one. The bushing I got is the same one jimrockford used for his bushing/needle bearing upgrade and I'm not doing the needle bearing upgrade. So can I still use the bushing without installing the needle bearing?
Old Feb 15, 2011 | 03:22 PM
TNRabbit's Avatar
The inside bushing SHOULD be the same....? Anyone else?
Old Feb 15, 2011 | 04:18 PM
squampton's Avatar
Wow you got to be kidding me. I paid $70 for that bushing and it says no returns for special orders on the receipt so I'm pretty sure I won't be able to return it if its the wrong bushing. Not even my fault if its the wrong bushing because I told the guy at the dealership I need a inner spindle bushing for a 1990 4runner. damn stealership...
Old Aug 18, 2011 | 05:01 PM
reliability's Avatar
brass bushings pn 90381-32001
I'm putting needle bearings into my free wheel hubs and don't know the correct bushings to use. Will pn 90381-32001 work for a 2000 Toyota tacoma with manual locking hubs???
aowRS
Sep 13, 2017 08:22 AM
G-off
Dec 29, 2015 12:44 PM
briholt
Sep 20, 2015 10:26 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Pocoyota
Sep 8, 2015 02:41 PM
