wont start error codes 22, 24, 31 , 41
You're getting ECT, TPS & VAFM codes. If the connections to those three sensors appear good, then check your E2 ground - that's the only wire those three sensors have in common. - It's a brown wire, maybe with a stripe (black??). Also check that the E1 terminal on the ecu has a good ground to the chassis.
Jnkml
Jul 6, 2015 01:20 PM
