Wobbly CV Joint
Wobbly CV Joint
On my 94 4runner (4X4), I can move the outer CV joint (only on the drivers side) by holding on to the CV Boot. I can move the CV joint about 1/8 of an inch in any direction expect in and out. When I am driving on anything but flat, smooth pavement, I can hear the CV Joint rattle. The CV Joint boot is not damaged. Is the CV Joint bad? Could it be caused by loose or damaged bearings?
Thanks,
Christopher
Thanks,
Christopher
Spindle bushings are gone.. pretty common.. I just replaced mine not too long ago..had the exact same symptoms. It'll get rid of the rattle you are describing. Don't let it go forever like I did because eventually the bushing will spin on the end of your CV axle and ruin it. It will make a really loud hum for about 20 seconds and then quit if that happens.
Yep. I just did mine too.
Your bushings are gone but are you sure the rattle isn't the brake pads slapping the rotor. Sometimes the springs that keep them apart stop working because they are rusted to death or have been damaged by heat.
kawazx636
Oct 6, 2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
