Wiring issues?
Old Oct 29, 2011 | 08:50 PM
Phessor's Avatar
Wiring issues?
I am building a buggy and I am having an issue trying to find out which wires go where? The engine and wiring harness is from a 1987 carburated truck.
I think I have the alternator figured out but please correct me if I am wrong.
Alternator:
Large white wire = battery +
Med white wire = battery +
Yellow wire = amp gauge
Red with double blue slashes = ignition
The coil is the big problem. All of the FSM's I have found only deal with EFI engines. So I need some help here as well.
Coil/igniter:
Black with red slashes = ???
Black with solid red line and red slashes = ???
Thank you, Phessor
Old Oct 29, 2011 | 09:19 PM
dropzone's Avatar
Fossilized
heads up your duplicate thread has been deleted
you can also find the wiring diagram using the link in my sig to the service manuals
Old Oct 29, 2011 | 10:53 PM
Phessor's Avatar
Thank you for the links. But all I could find where FSM's for EFI models. I still need to find one for the carburated version.
Phessor
Old Oct 30, 2011 | 05:43 AM
Hadmatt54's Avatar
This should do it for you, it's for an 86, but the wire colors look to be the same. On the igniter diagram, IG2 is on the ignition switch and the B/R wire goes through a noise filter and then to ground after it branches off to the igniter.
[IMG][/IMG]
MO transplant
Apr 23, 2023 11:58 AM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
