wiring harness ground wire location
Old Mar 27, 2008 | 03:20 PM
rvsmichael's Avatar
Im getting no power through my main wiring harness for injectors or anything else . I do know that my timing is out does this have anything to do with it? Beings that plug is on the distributor cap? I know my injectors are good. and everything ran good before the rebuild . i need to know the location of the ground wire on the wiring. I got the one on the fire wall to the head and the one on the battery cabble to the block grounded other than that Im lost. I want to blow it up. Help
Old Mar 27, 2008 | 03:21 PM
rvsmichael's Avatar
year is a 1986 22r-te
year 1986 22r-te turbo
Old Mar 27, 2008 | 04:42 PM
Targetnut's Avatar
there should be a ground point on the intake manifold where the plenum bolts on.
But that should not effect the power to the injectors and such, I'd be looking at fuses and fusible links.
Old Mar 27, 2008 | 05:40 PM
sloppy85toy's Avatar
look at the efi fuse on the the driverside kick panel.try crackin open the cold start injector and crank it over see if any fuel comes out.if not it more and likely is the efi fuse.mine did the same thing after i put a new motor in it it wouldnt start
MO transplant
Apr 23, 2023 11:58 AM
Doug4320
Mar 24, 2018 10:11 PM
v_man
Jul 23, 2015 04:01 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
