Wire harness swap question
So i've concluded that i need a new wire harnes after setting several differant codes for differant systems and replacing most said part parts with no improvement.
Ive got an 87 4runner 22re that is cali emision. My question is would i be able to swap in a fed emissions and be ok? or will that just not work?
I've swapped a few engine harnesses and didn't have too much trouble with it. If the harness is of a different year just make sure the ECU pinout is the same for your body harness. You can find all the wiring diagrams and pinouts online. Just google it. Good luck!
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
