wipers don't work
Old Nov 29, 2008 | 09:45 AM
91 yota's Avatar
wipers don't work
have not really looked to see whats wrong with them other than fuses. any suggestions on where to start? wasn't any fuses blew.
Old Nov 29, 2008 | 10:15 AM
just a 22re's Avatar
check at the wiper motor where the plug is they can get full of corrosion man i cant spell but just look at the connections and see and make sure there clean thats about it that i can think of right now
(used spell check man you had no idea lol)
Old Nov 29, 2008 | 10:33 AM
91 yota's Avatar
the connector looks good. how do i test to see if the motor is good? also is there a way i can check the wiper switch?
Old Nov 29, 2008 | 10:34 AM
yeah get a test light or a multimeter and check the wires at the motor and see if your getting power to it or not if you are then its the motor if not then its going to be the switch or a broken wire or fuse
Old Nov 29, 2008 | 11:22 AM
91 yota's Avatar
i ran a hot wire to the motor and it worked, also tested my switch and it tested good. the plate for the fuses is gone on mine so i checked all the fuses, which one is the wiper fuse? 91 pickup
Yota.Jay
Mar 6, 2016 11:02 PM
aciorba23
Jun 29, 2015 04:18 PM
cchinny
Jun 25, 2015 08:11 PM
gog1968
Jun 22, 2015 05:55 AM
