Windshield Install??
Old Mar 11, 2013 | 10:08 AM
Jesse Fullerton's Avatar
So I picked up a 91 4runner for pretty cheap about a month ago. it had been flopped onto its side and when i went to get the windshield replaced the body and a pillars turned out to be tweaked. Needless to say I've had safelite come out 3 times already after my attempts to straighten it up and they still havent been able to get it in. Now there is only about 1/4" gap inbetween the windshield and the a pillar. So my question is that if i have them come out one more time and they still cant get it in the "correct way" can I just buy the windshield from it and install it with some high grade silicon and get that to work? Or do you guys have any other ideas that might help me out? The body is extremely close to where it needs to be.
Old Mar 11, 2013 | 10:18 AM
scope103's Avatar
The mechanical strength of the roof, and to an even greater extent the retention of the windshield in an accident, is very dependent on how tightly the windshield is held in the frame. That's why they are so difficult to remove.
I don't have any particular insight into tests done by Toyota, but I would be rather fearful of a windshield held in only with "high grade silicon." Not only the risk it would pop out in an accident, but I'm going to guess that it will vibrate slightly with road stress and repeatedly open up the silicone joint (leading to leaks).
But its your truck and your health. Just be careful out there.
Old Mar 11, 2013 | 10:34 AM
Discombobulated's Avatar
Agreed!!
Possibly take it to a body shop and see what they think and what needs to be done. Is there any issues with the doors not shutting or anything else, I mean if the cab is tweaked it could get ugly.
Old Mar 11, 2013 | 10:40 AM
Yeah it didn't look so bad when I picked it up but it's going to get chopped up pretty good but it drills needs to be street legal, I figured I would get it in as close as possible with the install kit and just fill in the gaps with the silicone
Old Mar 11, 2013 | 10:53 AM
Co_94_PU's Avatar
Keep hammering, just takes some patience.
Silicone is just used for small leaks in the window glue, not a good idea to fil any major gaps.
If you want to cut your losses and just get it over with try sourcing a new pillar from the salvage yard.
If you plan to chop the top might aswell do it now, it'll save you cash and time. Much easier to straighten the pillar if it's only attached on one side, and you might be able to cut out the part thats causng the gap. And if you need a custom piece of glass no sense putting in the stock sized one.
4x4-runner
Apr 18, 2017 09:08 PM
Sep 4, 2015 09:27 AM
TDonkey
Jul 26, 2015 10:14 AM
chickenhala
Jul 21, 2015 05:41 PM
msane99
Jul 17, 2015 10:13 AM
