wierd vacuum hose problem
ok just saying the #2 vacuum hose doesn't tell us anything. due to the fact that it might of been changed at sometime or the #2 might be different on someone Else's if u can please take a pic of the hose and where its going then we might be able to help u figure out whats going on.
Take a look at this thread and check all your vacuum hoses:
https://www.yotatech.com/forums/f116...e-help-209069/
In post #1, the left picture has all the connections numbered, and post #11 tells you where to connect each end. I'd check all the hoses to make sure they're hooked up properly.
Bugs
Bugs
Thanks for the diagrams, I had #5 and #6 mixed up. The vacuum line to the egr valve and the one that goes around to the other side of the intake. I do have a question about #1 #2 and the plugged vacuum that goes to the gas filter. Does it matter which order 1 and 2 go in? I noticed that the gas filter is screwed in so it could be upside down according to the diagram. I hooked mine up according to the diagram using the little toyota imprint as a reference to the gas filters position.
the1998sr5
15
Jul 14, 2020 08:35 PM
TokyoD23
Jul 12, 2015 06:01 AM
Poncho0206
Jul 10, 2015 06:21 PM
