Why reverse?
Why reverse?
Just did some rear brake work and started reading up on adjusting the parking brake. I keep reading that you drive in reverse and continually pull the parking brake till it tightens. So why reverse? I can't wrap my head around how the brake would even know which way it was turning. Staring at the brake I can't grasp why reverse.
Not for Toyota`s this worked on older GM cars and others never on Toyota vehicles.
Backing up is what adjusted those older GM and other vehicles.
Our E-Brake adjusts the rear shoes from constant use although it helps to have them adjusted up to start .
At least I always do that.
I read the FSM on the adjustment which doesn't mention anything about driving while adjusting. Knowing the mechanism inside the drum with the cog and gear type setup I started wondering why it wasn't adjusting. So I pulled the drum off and watched it while reaching behind the brake and pulling the parking brake cable. The cog was just skipping off the gear. So I pulled the gear mechanism out and realized that it was pretty hard to turn. I cleaned it out along with the threaded part and coated it with graphite and reinstalled it and it worked perfectly. I left the back-end up on the jack and pulled the cable until the brakes engaged but still releasing enough to allow the wheels to turn without resistance. All is well.
Ilovemountains
Sep 15, 2015 04:17 AM
May-39
Sep 6, 2015 01:05 PM
