White Smoke at Startup, but goes away???
Old Feb 5, 2009 | 02:06 PM
Bullydog95's Avatar
Did my headgaskets last may and hoping I dont have one of the cursed 3.slows. I Made two reference marks on the over flow tank. One mark for cold temp and one at operating temp. That way I can know if I'm losing coolant or if it's just water vapor evaporting through my tailpipe.
Oh! And yotatech rocks! From the newbie.
Old Feb 5, 2009 | 02:10 PM
jhershner11@mac.com's Avatar
its normal condensation build up. mine does it too. I wouldn't be overly concerned right now. Try taking the cap off the radiator and starting the motor. Tell tale signs of a bad head gasket are bubbles boiling up in the coolant that will come out the fill hole in the radiator
Old Feb 5, 2009 | 02:33 PM
DupermanDave's Avatar
just curious, would this white smoke 1) destroy a new O2 sensor after a long time and 2) will it clog a new cat?
im having the same issues and have been needing to replace the o2, cat, and muffler since I got the truck.
Old Feb 5, 2009 | 02:34 PM
fireman1559's Avatar
bullydog there are already marks on the overflow tank why did you mark it? and you did your own HG job and you dont know if you have hte 3.0 are you sure you did it right then? im sorry but if you dont know what type motor you have after working on it you dont need to touch your truck again
Old Feb 5, 2009 | 02:35 PM
  #25
no it wont hurt anyof it
Old Feb 5, 2009 | 05:58 PM
  #26
abecedarian's Avatar
If the 'smoke' disappears within a few seconds, it's not smoke, it's steam. Perfectly normal when starting a cold engine. Even where I'm at in Mason Ohio, I can drive the car 30 miles and still see 'smoke' (steam) when I'm at idle and the ambient temp is below freezing, but it disappears within 10 feet or so of the car.
Old Feb 6, 2009 | 04:49 AM
  #27
njkev7's Avatar
Well this morning the smoke was there but I notice oil on the floor right under the motor. I pop'd the hood and notice what look'd to be oil that had leaked on the passanger side of the motor. Right between the intake cover. My oil is alittle low but I thought that was normal for 4runners.
Old Feb 6, 2009 | 07:04 AM
  #28
Marc's Avatar
What do you mean by a little low?
And no, it's not normal for any vehicle to be low on oil.
Old Feb 6, 2009 | 07:14 AM
  #29
njkev7's Avatar
A little low meaning that the oil gauge is a little lower than normal. But this is over time, and now thinking about it I'm due for an oil change.
Old Feb 6, 2009 | 07:48 AM
  #30
Marc's Avatar
Have you checked the oil level on the dipstick?
Old Feb 6, 2009 | 07:57 AM
  #31
njkev7's Avatar
No....
Old Feb 6, 2009 | 11:20 AM
  #32
Bullydog95's Avatar
Sorry 3vze.
I thought after coolant is burned in combustion chambers it cleans the hell out of it. clean as a whistle. wonder where all that carbon goes. 02 and cat could both be suspect in my opinion.
but what would i know.
puddlepirate
Jul 30, 2016 06:29 PM
Ditch Doc
Oct 27, 2015 03:20 PM
dzldust
7
Oct 6, 2015 05:39 AM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
