Whining through speakers
Old May 25, 2019 | 12:09 PM
Michael Brozick's Avatar
Brand new alternator, there is a bad whining noise through the speakers and the power steering pump just started making noise too, not to sure what to do please help I need to make it to work on Tuesday.
Old May 25, 2019 | 03:22 PM
Discombobulated's Avatar
Bad whining noise through speakers will be a ground, make sure all your main grounds at the battery and body are intact and not corroded, Double check your belt tightness for the belt noise.
:edit:
is your pump itself making noise or is it a belt noise, if all this started after the alternator was replaced double check everything you touched
Old May 25, 2019 | 07:26 PM
RJR's Avatar
RJR
A whining in the speakers that just started with the new alternator is quite possibly a bad diode in the alternator. There is a six-diode bridge in the alternator that converts AC (alternating current, hence the name "alternator") to DC for the 12V system. If one of those diodes is bad, you'll get excess ripple on the DC output and that will cause whining in the radio. I'd consider having the alternator checked.
Depending on how the diode has failed, it could be putting an internal short across the alternator output, greatly increasing the torque needed to turn the alternator, causing belt issues. Sooner or later things will go up in smoke.
Old Jun 4, 2019 | 11:28 PM
My power steering just needed some fluid but I get auto parts at a discount because of where I work so I said ˟˟˟˟ and bought a new alternator from Napa and it still has the whine but only when the radio is one, I’m guessing it’s probably something to do that not sure though
Old Jun 5, 2019 | 07:40 AM
RAD4Runner's Avatar
Originally Posted by Michael Brozick
...only when the radio is one..
Only when listening to AM or FM "radio", but no when CD plays?
Does whining change when RPM changes?
You know that the first-gen 4Runner uses transmission fluid, instead of power steering fluid, right?
Old Jun 6, 2019 | 09:46 PM
user6137's Avatar
When my radio was whining, I grounded the hood using one of the hood bolts as the attachment point for the ground wire. That fixed it for me.
TTsr54x4
Jul 11, 2018 12:00 AM
traben27
32
Dec 13, 2012 12:31 PM
Smelliottkuhn
Aug 17, 2012 09:04 AM
ThomasJ
33
Mar 8, 2012 08:16 AM
fireteacher
Jun 12, 2006 02:38 PM
