Where can I find a 22rte injector
Hey guys, i got a 1986 yota with the original turbo engine, doing some work on it and sent the injectors off to be cleaned and found out one of them has a damaged pintle and couldn't be serviced. So now im in a tough spot, I cant seem to find any 22rte injectors for sale for a realistic price. The dealership said it would be $250 for one. Any advice?
https://www.fiveomotorsport.com/fuel...oyota/?v=22355
This says its for the 22rte but it says the are 350cc injectors? Isn't stock like 295-300cc? Or should i trust what the website says
LC seems to say 300cc
http://www.lceperformance.com/22RET-...-p/1062003.htm
I "changed" ,my injectors over to the "disc" style.
I had to solder new injector connectors on, and modify the wiring harness, but once that was done, it was plug and play
If I recall, my 1989 "later" model 22RE uses higher impedance "Saturated" injectors, while the RTE uses the low impedance "Peak and Hold" type
https://www.rceng.com/Peak-Hold-Fuel-Injectors-C5.aspx
