What's this part called & why does anti-freeze leak from it??
Old Oct 4, 2010 | 08:27 AM
jpjp's Avatar
After the car gets warm and gets parked, it creates an antifreeze puddle below the round silver part to the right of the oil filter on the 3.0L engine on the drivers side.
What is this part called and would would it leak?
Could it be the gasket between it and the block?
Can it be rebuilt?
Is it easy to remove while in the car?
Thanks in advance.
jp
I am talking about the round/sliver part on the very right.
Old Oct 4, 2010 | 08:32 AM
thook's Avatar
That's the oil cooler. Time for a new seal. Search the forums. The info on replacement is around.
Old Oct 5, 2010 | 04:22 AM
jpjp's Avatar
Thanks
JP
Old Oct 5, 2010 | 04:59 AM
TNRabbit's Avatar
There are actually 3 rubber o-rings seals in it, IIRC. Replace them all.
Old Oct 5, 2010 | 05:34 AM
jpjp's Avatar
I just ordered all three!!
Let's hope it is easy to do and takes care of the antifreeze leak.
JP
Old Oct 5, 2010 | 08:41 AM
thook's Avatar
Yeah, I couldn't remember how many, but I knew atleast one...hahaha.
Old Oct 5, 2010 | 08:58 AM
1987efitoyota's Avatar
Can it be rebuilt?
Thanks in advance.
jp
Make sure u scrape the old gasket off really well and id reccomend using hi temp silicone on both sides of the seal to insure a leak free solution
Old Oct 5, 2010 | 10:28 AM
jpjp's Avatar
So the 3 gaskets alone are going to fix an antifreeze leak?
Old Oct 5, 2010 | 07:23 PM
GDR's Avatar
GDR
No
None of the gaskets seal any coolant.There are no seals for coolant. All those seals are for oil.
If you are leaking coolant then it is from the hose connections or the cooler itself is bad and leaking.
Old Oct 6, 2010 | 12:27 AM
thook's Avatar
Hmm....you sure about that? Just asking. I just looked at a diagram of the cooler. Couldn't tell much really, but it kinda looks like a little radiator inside there. Is that the case?
Old Oct 6, 2010 | 04:51 AM
TNRabbit's Avatar
Originally Posted by GDR
No
This is correct.
It runs oil & coolant around each other in a tiny radiator type of system. If the OP is leaking coolant, it is probably from the hose.
Old Oct 13, 2010 | 04:45 PM
jpjp's Avatar
This is correct.
Didn't need the three gaskets i bought. Fixed the problem which was leaky hose clamp.
Thanks for everyones input. Big Red lives on!!
jp
Jun 1, 2021 01:51 PM
Road Bull
Oct 10, 2015 04:55 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
