What is the difference between these??
Old Mar 8, 2020 | 04:01 PM
Jakez's Avatar
Old Mar 8, 2020 | 04:18 PM
Saturn's Avatar
They're oil pressure sending units. If I remember correctly the one on the left is for a full variable gauge and the one on the right is for a dummy light.
Old Mar 8, 2020 | 05:59 PM
Jakez's Avatar
Thats what I thought too..
I just took the cluster and sending unit out of an auto 95 4runner 4wd v6 and that's the sending unit it had..
I swapped both over to my manual 93 pickup 4wd 22re, plugged in my connector to the 4runner sending unit and the gauge seems to be working correctly...
Old Mar 8, 2020 | 08:15 PM
Co_94_PU's Avatar
disagree.
The left is a factory style sending unit, the right is not a factory style (but still probably a sending unit, you can tell the two apart typically by size of the diaphragm) maybe not even Toyota I don't recognize the plug but I've certainly not seen them all.
A "sending unit" implies a variable resistance output, not to be confused with a "switch" which is either open or closed.
Old Mar 8, 2020 | 11:07 PM
Jimkola's Avatar
YT Community Team
5 Year Member
They’re both sending units for a oil pressure gauge, not a light. The one on the right is for slightly newer vehicles. Probably the only difference is just a more positive lock of the connector.
dirtoyboy
Jun 25, 2008 11:37 AM
JEDI87
Oct 3, 2005 09:57 AM
4runner4me
North Carolina
13
Sep 21, 2004 12:08 PM
