What did i do or am i just paranoid coolint issue
Old Oct 25, 2007 | 05:43 PM
gametom's Avatar
ok so heres the deal i have been woking on this truck for aabout a month and a half. started with i needed to ge the injectors cleaned. so i took it apart and got that done when i put it back together i had fuel leaks. after i took care of those then my radiator had a leak. now there's a new radiator in there. ok so i was letting it warm up and noticed water dripping out of the exaugst figgerd no bigge just condensation it's in the 50s outside right now so the coolent level in the radiator isent moving and there white smoke coming out the top of the radiator but it smells like coolent the exaugst dosen't smell sweet. the other thing i noticed is the top of the radiator is hot but the bottom is cold i turned the heat on and it was blowing hot air the temp gauge was dead center.
the oil looks like oil i don't know what else to say
also the idil was all over the place. is my t stat not opening, my water pump not working or is there just a leak in my intake gasket / head gasket
I need my truck back people are getting feed up with me barrowing autos Help
my biggest problem is i have no time to work on it when i get home from work i can ether go right to the part store or work on my truck for an hour or two weekends are my only chance to have time to wrench
Thanks to all on this forum this is the only reisen i haven't gotten way to far in debt to buy something new
I feel like a idiot right now
Old Oct 25, 2007 | 05:45 PM
gametom's Avatar
i want a pickup with the 22r or deisel
but have no money
Old Oct 25, 2007 | 05:57 PM
mt_goat's Avatar
The water pump is working or the heater wouldn't work. The t-stat isn't open if the lower radiator hose is cold. The 22re has a bad heater hose design that will close the t-stat in cold weather if the heater is on. There is a special t-stat avaliable that will fix that problem, look here:
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
I don't know about the smoke out of the radiator problem, unless you have a bad head gasket.
Old Oct 25, 2007 | 06:07 PM
gametom's Avatar
so the top being hot and the bottom being cold is normal?
Old Oct 25, 2007 | 06:11 PM
mt_goat's Avatar
Normal for a closed t-stat but a closed t-stat is not normal for an engine thats overheating unless you don't have that updated t-stat in the link I posted above. Does that make sense?
Old Oct 25, 2007 | 07:00 PM
davenjai's Avatar
Put the radiator cap back on.
Old Oct 25, 2007 | 07:10 PM
gametom's Avatar
so am i ok?
Old Oct 25, 2007 | 07:20 PM
davenjai's Avatar
so am i ok?
It's a pressurized system. With the cap off you will never know. Put it on. If all is well.....then all is well.
Last edited by davenjai; Oct 25, 2007 at 07:29 PM. Reason: Not enough info for meathead
Old Oct 25, 2007 | 07:26 PM
paxil4x4's Avatar
Drama Queen/Banned
Did you have a seizure when you typed this post?
Old Oct 25, 2007 | 07:28 PM
davenjai's Avatar
Do you have Arby's on your brain?
Old Oct 25, 2007 | 08:04 PM
gametom's Avatar
i can think so much faster than i can type and i get confused, and i haven't gotten much sleep lately.
Old Oct 25, 2007 | 08:06 PM
gametom's Avatar
i could go for Arby's right now mmmmm beef like substance and cheese
Old Oct 25, 2007 | 08:09 PM
ozziesironmanoffroad's Avatar
oh god your making me salvitate. i hope i spelled that right. off to get arbys. if theyre still open that is.
Old Oct 25, 2007 | 08:19 PM
gametom's Avatar
so seriously i should just drive it and see what it does before i do anything else right?
Old Oct 26, 2007 | 03:59 AM
mt_goat's Avatar
Does the lower hose get hot with the heater off?
Old Oct 26, 2007 | 06:09 AM
gametom's Avatar
i haven't tried that yet when i get home today that's my first test.
Old Oct 26, 2007 | 06:39 AM
mt_goat's Avatar
Make sure you run it long enough for the t-stat to open.
Old Oct 26, 2007 | 02:27 PM
gametom's Avatar
will do
Old Oct 26, 2007 | 03:21 PM
Targetnut's Avatar
MMMM...Arby's....MMMM
go for a test drive, see if it works OK. If there is coolant spilled on the radiator it will have to get driven around before it all evaporates and it stops steaming.
I'm betting on paranoia here, but the only way to find out is drive it.
Just keep an eye on it while you do.
Old Oct 26, 2007 | 05:10 PM
gametom's Avatar
i hope so
and i hope i get off work soon 10hour days suck
