Water pump gasket question
Old Jun 12, 2015 | 05:40 AM
jener8tionx's Avatar
Hey guys: I got this gasket with my Aisin water pump. Generally I blue rtv both sides of the gasket, but this one has a rubber ring. How do you guys suggest installing this type of gasket?
Old Jun 12, 2015 | 06:18 AM
Terrys87's Avatar
I am guessing that is a 3.0 gasket? I like the idea of the rubber seal on it. I personally would put a thin coat on both sides. I have not done a 3.0 water pump gasket but some one with experience on it will give better advise.
Old Jun 12, 2015 | 06:23 AM
Yes, it is a 94 3.0
Old Jun 12, 2015 | 01:59 PM
superex87's Avatar
Aisin parts are oem and Toyota did not put rvt on it from the factory. So I would say no to the rvt. If it was a paper gasket that's a different story.
Old Jun 12, 2015 | 05:59 PM
rworegon's Avatar
The gasket that came with the AISIN WP is a fine gasket. It's been installed as-is without RTV or any other additional goop on several 3.4 WPs I've done and never have had a single issue. I see no reason why the performance on the 3.0 will not be the same.
Old Jun 13, 2015 | 01:06 PM
wyoming9's Avatar
Red face
Do what ever makes you happy.
If you don`t do the blue silicone I myself would wonder every time I went some place is now the time it starts to leak.
I know in my case it is all physiological
We all have our on thing Just like I refuse to weld on a vehicle without removing the negative battery terminal.
Old Jun 13, 2015 | 03:42 PM
I went without the blue sealant. I'll report back after I start it up tomorrow, and again if it leaks in the future.
Old Jun 26, 2015 | 09:03 PM
I have little to report because it's been parked pending locating the leak in the back of the engine. I thing it's the number 1 bypass tube.
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
