water outlet on bottom of intake manifold SUCKS
Old Jun 18, 2008 | 08:39 AM
kd's Avatar
kd
is there any trick to putting this on. its sandwitched between the starter ans intake manifold stud coming out from the head. so it has to be put on in place i think. just messed up a good manifold because of this thing
Old Jun 18, 2008 | 02:30 PM
abecedarian's Avatar
umm... if it's between the starter and the manifold...
why not remove the starter?
Old Jun 18, 2008 | 08:46 PM
khany2002's Avatar
This thing screwed me over when I replaced my headgasket.
What I did was loosen the fuel filter frame (what you are mistaking to be your starter) from the block, and created enough space to install that metal water hose. Without doing that, I saw no way of completing the install.
It set me back a good 3 - 4 hours, and I feel your pain. It annoyed the out of me, and many times I considered simply cutting it and running heater hose around the engine (although we all know that is a terrible idea!).
After all the work, I don't think about it anymore, but, I definitely sympathize with you.
Best of luck.
Old Jun 18, 2008 | 09:03 PM
kd's Avatar
kd
thanks i realized it was the fuel filter and decided to replace it because there is almost no way to get in there without pullung the manifold and i dont want to do this again it i dont have to. im supprised how difficult it is to work on this motor. its like you need the hands of a small child to get to some of these areas.
Old Jun 19, 2008 | 01:29 AM
Ezrider_92356's Avatar
i had a hell of a time with that one as well, removed the fuel filter and the fuel filter mounting bracket.
steve miller
Oct 10, 2015 01:40 AM
TJWilly
Jul 31, 2015 02:05 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
