vibration in front
Old Feb 4, 2006 | 02:48 PM
jeff2146's Avatar
vibration in front
i just got a 95' 4runner 4x4 its got 170,000 miles and is in ok shape but needs some work. my first problem is a vibration in the front. i jacked up the front and you can grab the right front tire at 12 and 6 oclock and there is a good bit of play. i have taken the rotor off of the spindle but now i dont know how to tell if its a bearing or the shaft. any one know please help.
Old Feb 4, 2006 | 04:05 PM
nunsa's Avatar
Greetings,
Are you sure it's a bearing and not a tie rod? To diagnose a bearing the best advice that I can give you is to put your rig up on a rack and put it in drive, get under there with a mechanic's stethescope you will be able to pinpoint the bearing: "Warning: Don't try this at Home!" If it were to be a bearing sometimes you can diagnose it be turning the wheel by hand and some times you can feel it, I'd really check those tie rods though!
Good Luck,
Harry
Old Feb 4, 2006 | 04:22 PM
jeff2146's Avatar
bearings
thanks, what about the play in the wheel, is this normal?
Old Feb 4, 2006 | 05:00 PM
UKMyers's Avatar
The play could be from bad balljoints, tie rod ends, idler arm or pittman arm. Wiggle the wheel and look and turn it slightly back and forth and look under the truck for stuff moving that shouldn't be.
88sasturbotoy
Jan 30, 2026 01:57 PM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
