vibrating a lot on highway 1990 toyota 2wd
Old Nov 13, 2012 | 02:22 PM
shafner30's Avatar
ok i have been having this vibrating thing going on for sometime.
going over 50mph on highway the truck vibrates really bad i can feel it in my seat and floor board vibrates.
the u joints are nice and tight and have a brand new trans mount.
ok i have changed:
got new tires.
got a wheel alignment.
got brand new front wheel bearings.
and it still vibates a lot .. what to do now?
help
where do i go now?
let me know thanks
alex
Old Nov 13, 2012 | 02:27 PM
Bucholz24's Avatar
The ujoints in the drive line has no play in it?
Old Nov 13, 2012 | 02:30 PM
shafner30's Avatar
no play
Old Nov 13, 2012 | 02:32 PM
Bucholz24's Avatar
did it start doing it right after you got a allignment
Old Nov 13, 2012 | 02:33 PM
shafner30's Avatar
no way before the new ties and alignment
Old Nov 13, 2012 | 02:35 PM
shafner30's Avatar
tires
Old Nov 13, 2012 | 03:18 PM
Bucholz24's Avatar
hmm. Mine has a viberation but its the ujoint. Have you checked your back lash
Old Nov 13, 2012 | 03:35 PM
z31freakify's Avatar
have you checked your wheel bearing you will be surprise
Old Nov 13, 2012 | 03:58 PM
shafner30's Avatar
the backlash from the diff the is a little play not much
Old Nov 13, 2012 | 04:00 PM
shafner30's Avatar
got brand new front wheeling bearings
the back wheel bearings are tight
Old Nov 13, 2012 | 04:04 PM
HighLux's Avatar
Ball joints? check rack bushings?
Old Nov 13, 2012 | 04:19 PM
shafner30's Avatar
ball joints good
rack bushings good
Old Nov 13, 2012 | 05:23 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
could 1 of your rims be out of round, or bent? Do you feel any kind of roughness in or thru the steering wheel? You might have a bad motor mount. Do you really feel the vibration when accelerating, or just cruising over 50? Check your cv joints.....
Old Nov 13, 2012 | 05:41 PM
mudpunisher's Avatar
its 2wd, check the strut bar bushing on the front, mine were bad on my old nissan hardbody and it would shake like crazy.
Old Nov 13, 2012 | 06:07 PM
shafner30's Avatar
it vibrates in the seat not much in the steering wheel just cruzing on highway over 50mph ever when i let off of the gas it still does it
Old Nov 13, 2012 | 06:17 PM
possibly take it to another shop and have the tire and rim runout checked, could be a bad tire, we get them from time to time at my shop.
Old Nov 13, 2012 | 07:13 PM
ahhhh, my bad, I forgot the 2wd part.....lol
Old Nov 14, 2012 | 10:44 AM
GrandPrix's Avatar
Had same problem on a new set of tires one month ago. Finally had a road force balance done and they found one of the new tires out of spec. Tire Rack took the bad one back, sent me a new one and paid for the balance and remounting. All this after I had a new drive shaft center bearing installed. Drives good now at all speeds. I will soon be changing my wheel bearings, and u joints just because.
Old Nov 22, 2012 | 12:25 PM
shafner30's Avatar
Ok i got a one peice drivelive, new tires new front wheel berrings
the vibrating is in the rear
i rotated my tires from back to front vice veasa
u joints are tight . It does it sometime on the highway going 50 mph
it seems to do it more when a make a lane change or going around a turn on the highway
it all so seems to do it more to when going up hill a little on the high way and down hill to on highway
i did not take the bolt out of the bottom of the shock let on the rear end
would a bad rear shock cause it to vibrate?
Old Nov 22, 2012 | 12:47 PM
might be your transmission going bad or your drive shaft might me bent
