Vent/return lines? Which is which
Old Apr 13, 2011 | 08:09 PM
Numbchux's Avatar
Getting ready to reinstall the fuel system in my truck.....which is which on the tank? Does it matter? I'd rather not have to pull the pump assembly just to identify the 2 ports.
Old Apr 13, 2011 | 08:11 PM
justin_4runner's Avatar
yes it matters but but try blowing down them with the return off and u can tell that way or follow from filter back and see what one is the feed.
Old Apr 13, 2011 | 09:12 PM
Sportsmanphil's Avatar
Yes it matters.
WIth the pump wired, lay a rag near the pipes and have a buddy cycle the ignition switch for a second. The one that sprays is the output.
I have no idea if blowing into them will tell you what you need to know as I have never tried it therefore do not know what to expect.
Cycling the ignition will def tell you which is which.
If you fear of a little bit of gas hitting a rag, simply place a rubber hose on each and run them to a bucket then cycle the ignition.
Old Apr 14, 2011 | 06:56 AM
Numbchux's Avatar
Originally Posted by Sportsmanphil
Yes it matters.
The send line is easy. it's bigger and has a flare nut on it. I'm asking about the other 2 as they look identical.
Old Apr 14, 2011 | 09:09 AM
here is a link for the fsm on your truck, on page 269 is a pic of the fuel lines and that, im not sure if this is going to help or not but give it a min to load,
http://www.ncttora.com/fsm/87-4Runne...4runner_88.pdf
Old Apr 14, 2011 | 05:47 PM
Numbchux's Avatar
That was the first place I looked.
I had a thought at work today, though. There's still a bunch of gas in the tank. So I blew in the 2 lines, one of them made a bubbling sound......
Old Apr 14, 2011 | 06:45 PM
thats what i was thinking bubbles meaning return line...
Rickstwowheels
Sep 10, 2015 03:51 AM
Duppie007
Aug 25, 2015 11:51 PM
Duppie007
Aug 25, 2015 03:05 PM
pyramid
Jul 30, 2015 10:05 AM
Fundy Rider
Jul 16, 2015 01:35 AM
