Valve cover knock 95 4Runner 3vze
Old Sep 16, 2023 | 06:20 PM
Lbrownie's Avatar
I’ve got a bad knock under the passenger side valve cover. Removed plenum and valve cover, found baffle failed and fell and first cam lobe was hitting baffle. Replaced valve cover with used OE cover (picknpull special) and the knock persists, sounds and feels exactly like original issue. Cam looked fine and all caps were tight. Truck runs good so it doesn’t seem like a stuck valve or anything. Just not sure why the cam would be hitting the baffle. Any help and knowledge is very much appreciated!!
Old Sep 18, 2023 | 05:52 AM
Hairyberry's Avatar
Do you have good oil pressure? If that is good I would say it probably needs the valves adjusted which is a bit of a pain but is necessary to keep a 3vz running right
Old Sep 18, 2023 | 06:00 AM
Lbrownie's Avatar
I’ve got good oil pressure and the truck runs great, I’m going to tear into it again this afternoon and check clearances and I’ll keep the thread updated on what I find.
Roark
Sep 17, 2023 05:37 AM
coleman75
Apr 1, 2012 10:46 PM
wyoguns
Oct 2, 2011 12:25 PM
Jim_M
Mar 26, 2011 06:16 PM
hmbrews
Jan 30, 2010 05:05 PM
