Valve adjustment 1993 4x4 with 22re
Old Apr 2, 2024 | 09:11 PM
jmckercher2010's Avatar
I purchased and high performance head from LC Engineering,. The valve adjustment specs are intake 8 thousands exhaust 12 thousands. It won't start zero compression. The mechanic that installed the head
adjusted both the intake and exhaust 10 thousands. LC Engineering has no explanation why it won't fire up with the 8 and 12 thousand spec.
Old Apr 3, 2024 | 07:40 AM
Jimkola's Avatar
YT Community Team
5 Year Member
No, the engine won't start with zero compression.
I'd go after that first. A leak down test would be informative.
Old Apr 5, 2024 | 09:54 AM
osv's Avatar
osv
22re cam has .393 of lift? i don't see how a couple of thou difference on the valve lash would give you zero compression.
how do you know that it has zero compression?
Old Apr 6, 2024 | 07:08 AM
mechkw's Avatar
I would check that the mechanic installed the timing chain correctly. Even if he adjusted both intake and exhaust at .010 it should still start. No compression on a new head would indicate wrong valve timing and hope he didn't get it too far out and bend the valves. THAT would give you zero compression. 8 and 12 on the valves is a hot adjustment, if adjusting cold you can go 7 and 11 respectively
89whitetoyota
Jun 25, 2024 06:12 PM
StorminMatt
Dec 20, 2022 06:42 PM
wodewose
Oct 5, 2018 06:26 AM
kmcmahon93
Jan 15, 2016 09:41 AM
shanesanders
May 6, 2009 05:08 PM
