Vacuum Lines Ahoy!!! Need some help figuring what goes where.
Old Feb 10, 2007 | 11:17 AM
Kyle95sr5's Avatar
Alright so im trying to figure out where all my vacuum lines are supposed to go.
First question, this little 3 port thing on the side of the intake. The one on the top left. There are 3 little ports coming out in the shape of a triangle. Where are all these hoses supposed to come from. KEEP IN MIND that mine is exacly upside down. If you look at it closely it says Toyota. There is supposed to be 1 on top, and 2 on the bottom.
Also, the one on the bottom right. Same 3 port kind of thing. Where do all of them go.
Second, where are the lines from the green vsv and the orange one right beside it supposed to go. Im talking about the lines that go straight up between the air filter and the actual thing. You can see both the lines in the picture and the port into which im reffering too.
Sorry for the confusing pictures and descriptions.
Old Feb 10, 2007 | 11:26 AM
MudHippy's Avatar
4 hope you get it, me take too long to get pic.
Old Feb 10, 2007 | 11:30 AM
Kyle95sr5's Avatar
What are you trying to tell me? I'm not catchin what your throwin...
Old Feb 10, 2007 | 11:40 AM
MudHippy's Avatar
I think your 1 and 2 hoses are correct. The three little ports should be 6 top, 5 to left of 3, both below 6. 4 hose goes below all, to AS reed valve. I try to figure the rest, are you having trouble with what # hose, originates from where or are you sure the hoses are where they should be?
Old Feb 10, 2007 | 11:45 AM
Kyle95sr5's Avatar
Once again, I have no idea what you are saying man. I need to know just where the hose goes. Like on the 3 port thing, what hoses are supposed to connect to it, and where are the supposed to originate from? Also, where are the lines that come off of the green and orange thing supposed to go.
Man this is confusing to type, and to understand.
Old Feb 10, 2007 | 11:46 AM
MudHippy's Avatar
O.k. I get ya hold on a sec'. Well see if this helps, Green has 3 and 6 , left to right standing looking from front of engine comp. Orange has 2 and 5, left to right. Blue has 1 and 4, left to right, nearly touching. Is that any better? I won't give up on ya.
Old Feb 10, 2007 | 11:48 AM
Kyle95sr5's Avatar
alright man.
Old Feb 10, 2007 | 11:53 AM
LS1Steve's Avatar
they plug into these orange and green things.
going by your pic, the "top" one goes into the near side of the green plug in my pic.
by your pic, the bottom right goes into the opposite (far) end of the green plug, and the bottom right goes into the opposite far end of the orange plug, make sense?
Old Feb 10, 2007 | 11:56 AM
Kyle95sr5's Avatar
Which of the 3 port things are you refering to. The top left or the bottom right one?
Edit: There are two bottom rights in your description. Which bottom right is supposed to be a bottom left.
I think you referring to the bottom right 3 port thing.
Old Feb 10, 2007 | 11:57 AM
MudHippy's Avatar
Woe , that's a bit different lookin' there. Mine looks exactly as pics at top not above. Bottom if your askin' me.
Old Feb 10, 2007 | 12:02 PM
LS1Steve's Avatar
the bottom right isn't labeled, but it is at the same point on the green plug that the bottom left (BL) is on the orange
Old Feb 10, 2007 | 12:03 PM
MudHippy's Avatar
Does your #2 line split like that? Mine don't.
Old Feb 10, 2007 | 12:04 PM
LS1Steve's Avatar
not sure but maybe my truck being a CA version has some differences
Old Feb 10, 2007 | 12:08 PM
MudHippy's Avatar
Yeah, could be. I need to get this pic postin' deal figured. I'll be busy on that for a minute, I'll check back with ya.
Old Feb 10, 2007 | 12:29 PM
LS1Steve's Avatar
Old Feb 10, 2007 | 12:33 PM
Kyle95sr5's Avatar
you are the man :bigclap:
In this picture, this is the bottom right 3 port thing correct? What about the top left 3 point thing?
Old Feb 10, 2007 | 12:52 PM
LS1Steve's Avatar
ok, heres your pic. the big one is unlabeled, so I called it 'A', it goes across along the firewall to the power brake hydraulics
the next one to the right, labeled *, goes several places. t's off and goes to passenger side
also goes across along with A over to here where it also connects in multiple spots
Old Feb 10, 2007 | 12:58 PM
Kyle95sr5's Avatar
And #1 (the one with the orange filter inline with it) goes into the top hole on the top left 3 port thing? Don't go by my pic. On YOUR truck it should be shaped like
Toyota
2 *
Is that how YOURS is set up?
MudHippy's Avatar
Just wanna try this, to see how it goes. Sorry if no use. TOO SMALL ME TRY AGAIN. AHHHHH..... Much Betta!
Old Feb 10, 2007 | 01:11 PM
Corey's Avatar
Co-Founder/Administrator
See if this helps
http://www.pnw4runners.com/index.php...e=M_VACUUM.PDF
