vac leak?
vac leak?
ok so my 93 runner 3vze motor has been idleing around 1500rpms when warm, its not the cold start as it revs even higher when cold, i adjusted the idle screw, sweet now she idles around 7-800, but it surges.. will jump up to 1200 or so then back off immediately... i should mention that it did this bfore it turned the idle down, but not as extreme... my question is... would a vac leak cause this? it was my understanding that a vac leak would make it idle low.. also..any tips for finding this possible leak would b extremely helpful
ya, i tried to spray starting fluid around the intake, nothing, should i use something else? The intake is coming off tomorrow anyway, as i need to do my knock sensor, hopefully ill find something then
Avenged
Jul 9, 2015 07:55 AM
