V6AT wont shift into OD
Old Mar 18, 2006 | 06:06 PM
881stGenRunner's Avatar
I have a 1988 4runner and it runs great and all but when it is cold it will not shift into OD. It has to be driven around for prolly about 30-45 minutes before it shifts out of 3rd gear. When it does it hits like a mid between 3 and 4. Say im going 60MPH that is apx. 3000RPM when it shifts to the mid gear it drops to about 2400-2500RPM then about 15-25 sec. later it goes into OD and drops to around 2000RPM. If anyone has any suggestions on what is happening it would be greatly Appreciated.
Old Mar 19, 2006 | 05:31 PM
dstrick32's Avatar
To my understanding the transmission is controled by the ECM and will not shift into OD until the engine reaches a certain temp. On my 94 Pick up it's about 145 degrees by the gauge. 30 to 45 minutes seems like a little to long and you may need to check your engine temp sensor. As far as the other shifts mine has been that way as long as I can remember unless I've got the hammer down.
Old Mar 19, 2006 | 05:44 PM
regularguy412's Avatar
Or the Tranny Fluid temp sensors. I believe there are two of them on an A340H.
MIke in AR
Old Mar 20, 2006 | 03:23 AM
aight yall thx.
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
