using the clutch start cancel switch as a kill switch
Old Dec 8, 2005 | 01:38 AM
YotaJunky's Avatar
I read somewhere that if the wires from the clutch start switch on the cab floor are disconnected (it's actuated by fully depressing the clutch pedal to the floor), then the clutch start cancel switch on the dash can be used to start the vehicle.
I also read in my owner's manual that the vehicle should not be normally started using the clutch start cancel switch.
I'm just looking for a cheap kill switch and was wondering if anyone uses this technique as a deterent for would be theives.
Any thoughts?
Troy
Old Dec 8, 2005 | 05:13 AM
ken.vs.ryu's Avatar
I don't see how it can act as a kill switch.
People steal gen 1 toyota's?
Old Dec 8, 2005 | 05:52 AM
Unhappy99's Avatar
The reason not to normally start the truck using the clutch-start-cancel switch is for safety. The truck can fire and run, transforming your garage into one of those convenient drive-through models.
The cancel switch is wired in parallel with the pedal switch, allowing either switch to start the truck. I am not intimately familiar with the wiring diagram, but if the cancel switch/wiring could be rewired to be in series with the pedal switch, then you would have to press both the pedal and the cancel switch to get it to start.
Old Dec 8, 2005 | 06:53 AM
YotaJunky's Avatar
I didn't know what else to call it. Unplugging the cancel switch may mimick what a starter kill switch would do. A would be thief may think that the starter was cut off while trying to start the vehicle with the clutch pedal depressed.
I don't know about other places. I can speak for British Columbia in Canada. It's on our list for one of the top 25 most stolen vehicles.
Here are a couple of links:
http://www.baitcar.com/prevention/to...itish_columbia
http://www.icbc.com/crime-fraud/pdf/PI213M_(042005).pdf
Troy
Old Dec 8, 2005 | 07:03 AM
YotaJunky's Avatar
Are you saying that the truck can fire and run without inserting the key? I disconnected the pedal switch last night and could only start it up by turning the ignition key to the position just before firing, pressing the cancel switch, and then turning the key fully to fire it up. Is there another way?
I like the idea of rewiring the pedal switch in series and hiding a toggle switch to close the circuit, thus requiring both pressing the pedal switch and closing the toggle switch to get a start. That makes sense to me. I'm going to look into it today.
Thanks for the idea!
Old Dec 8, 2005 | 07:06 AM
YotaJunky's Avatar
Also, does anyone have an idea of how I can wire in a blinking light that activates after the engine stops running? I want it to like look there's an alarm or immobilzer device installed.
Troy
Old Dec 8, 2005 | 07:22 AM
ken.vs.ryu's Avatar
http://www.nifty-stuff.com/car-alarm-1.php
Old Dec 8, 2005 | 07:51 AM
Unhappy99's Avatar
Sorry for the confusion. No, the truck will not start without the key. The pedal switch allows the ignition switch to power the starter. The cancel switch does the same thing as the pedal switch.
If you get into the habit of using the cancel switch instead of pressing the clutch, you risk making the mistake of leaving it in gear, pushing the switch and keying the starter when you really shouldn't, such as in your garage.
Attached blinky light circuit. I would go with Method 2, unless I could find a really good ground-with-ignition-off wire. i.e. one that doesn't care that you pump 20mA back through it.
Or, if you can find a hot-with-ignition-off wire, use Method 1, replacing the +12 with the hot-with-ignition-off wire and taking the other end directly to ground
Attached Thumbnails using the clutch start cancel switch as a kill switch-blinky.gif
Old Dec 8, 2005 | 08:16 AM
YotaJunky's Avatar
Thanks again! I'll look for a hot-with-ignition-off wire first and then take if from there.
Troy
Old Dec 8, 2005 | 07:01 PM
YotaJunky's Avatar
Originally Posted by Grounded
Apparently the Accord I purchased was broken into in the past. The Accord is not listed on the ICBC list, but it is listed on the baitcar list. Looks like I'm going to have to look into an immobilizer/alarm.
I'm still waiting for my CAT (Combat Auto Theft program in B.C.) label to come in the mail. http://www.icbc.com/Crime-Fraud/auto...fta_catprg.asp Hope it comes soon!
Yes, indeed Pat! An immoblizer is a must, especially for your Accord. It's just a sitting duck waiting to be lured into a chop shop.
BTW, I was able to get my CAT sticker at the Steveston Community Police station without having them mail anything to me.
Troy
Old Dec 8, 2005 | 07:33 PM
Silver_Truck's Avatar
Just unplug the little connector down by your clutch and yes you'll have to use the clutch start cancel button...I've done and a bunch of other people on here have done it, I highly doubt its bad for the truck in any eay. i did because I don't want people trying to drive my truck who I don't want to (i.e someone stealing it, valets, friends, family etc.)
Old Dec 8, 2005 | 08:03 PM
YotaJunky's Avatar
I'm going to take it one step further and install a toggle switch in series with either the clutch-start-cancel switch, or with the clutch pedal switch and disable the clutch-start-cancel switch.
Troy
Old Dec 9, 2005 | 03:07 PM
braverex's Avatar
Why not just wire a toggle switch in series with your fuel pump... and then hide the toggle switch under the dash or something? Your car won't start with out fuel, thought it sounded like a good solution?
Old Dec 9, 2005 | 04:25 PM
AxleIke's Avatar
this is a most excellent thread...my clutch switch has been removed for years, a toggle switch down there will do nicely, and maybe another in the engine bay....i'm taking a road trip to san diego...
Old Dec 9, 2005 | 08:07 PM
BAZ's Avatar
BAZ
Sorry, I'm a retard and I need clarification here: With the clutch switch disconnected, is it possible to start the truck without the key? (like if someone were to try to steal it)
Old Dec 10, 2005 | 01:00 AM
YotaJunky's Avatar
I don't know anything about hot wiring a car. Does anyone else care to chime in? I would like to know also.
Troy
Old Dec 10, 2005 | 04:50 AM
85TurboRunner's Avatar
sweet it says 86 and up runners get stolen more, phwew im glad i have an 85.
Old Dec 10, 2005 | 07:53 AM
YotaJunky's Avatar
Your solid axle has a high drool factor for would-be thieves that want to do off roading or parting out. If it were my rig, I wouldn't risk it, especially if you are already out in the middle of nowhere. I've heard that for early model yotas, there weren't that many keys made and that makes it even easier to steal.
Troy
Old Dec 12, 2005 | 10:21 AM
boyota's Avatar
Troy
NO, the truck will not start w/o the "kill" activated/energized. the clutch switch is a safety element (so you don't create a drive-thru from the garage, see above). i think what you want is an additional theif deterrent. moving the clutch switch to a secret place does this, but you lose the safety feature. an additional switch which cuts off the electrical supply to ...say the starter will do this. the elect fuel pump is another good one. at this point think of the key as a steering lock.
the key start could then be by-passed to create a push button start (secret location again) in conjunction with the clutch switch. my friend had his wired into the high beam passing (the momentary switch, not the ON) on the column. pull the high beam, push the clutch, turn the key...vroooooommmm. any ??
Old Dec 12, 2005 | 10:51 AM
YotaJunky's Avatar
Very cool. Did he run the high beam wire in series with the clutch pedal switch? Is it an easily accessible wire without taking any part of the steering column apart?
Troy
