Used Engine
Old Aug 9, 2010 | 08:10 AM
lewisaricl's Avatar
Used Engine
Well the 3.0l in my 89 is locked up. I have been searching and I foumd a guy that has one out of a 94 for $700. I don't know if its the original motor or not so I cant say what the milage is. What I was wonderimg anout is should I get a new oil and water pump for it. Im gonna get new headgaskeys and head bolts. Also im gonna replace the rear main seal. What would you guys do.
Old Aug 9, 2010 | 08:18 AM
rattlewagon's Avatar
You can check the vin number on the block and the cab, if they match, its original. Also know that because of the year difference, some things might be different, such as electrical plugs, exhaust manifolds, etc.
Old Aug 9, 2010 | 09:30 AM
lewisaricl's Avatar
If the manifolds dont work ill prolly just get headers. Ive read that the stock manifold crossover causes the #6 cylinder to heat up and blow the head gasket
Old Aug 9, 2010 | 09:23 PM
lewisaricl's Avatar
*bump*
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
