Urgent: Need help with timing chain have pictures
Old Apr 16, 2013 | 10:13 AM
zydeco42's Avatar
Hello everyone again. I am getting real close to buying a 93 Yota 2.4.L Truck and I am unsure about the timing chain. The salesman said by the look of the new bolts the chain appears to have been changed. Is that true? Any feedback is greatly appreciated!!
Old Apr 16, 2013 | 10:40 AM
snobdds's Avatar
Unless anyone has xray vision, there is no way to tell. Only way is to open her up and see if the guides, chain and tensioner are new.
Sorry, no other way around it...
Old Apr 16, 2013 | 11:14 AM
Duckie's Avatar
Snobdds is right. You can kind of see down into the cover if you remove the valve cover and use a flashlight. At least checking to see if the guides are intact.
Old Apr 16, 2013 | 12:15 PM
Spazzcdnm's Avatar
If its got the metal guides then it is guaranteed to st least be newer. May still be old. But they arent factory. There is always the possibility of then replacing then with plastic guides. But if the original ones are in there. Then chances are that they are broken.
Old Apr 16, 2013 | 02:17 PM
thefishguy77's Avatar
Let the salesman know that you know it's a $1000 job head gasket should be done at the same time. It can be done with out a head gasket but most people bugger the head gasket trying to put the cover back on with it being very right between the head and oil pan. Unless he has proof assume it has not been changed
Old Apr 16, 2013 | 03:08 PM
Yotard's Avatar
remember this guy is trying to sell you something so he is going to tell you whatever you want to hear to make the sale. He doesn't care if it has or has not been done.
msane99
Jul 11, 2015 08:08 PM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
elwood73
Jul 5, 2015 07:07 AM
