UHHHH OOOO!!! air box filled with oil!!
Old Aug 15, 2009 | 06:51 AM
nygaard208's Avatar
man i have run into more issues with the 3.0 that when i pull the motor im going to dissassemble it with a sledge hammer...
so what causes this thing to back feed into the airbox?
im comtemplating rebuilding this motor but im kind of hesitant too...
Old Aug 15, 2009 | 06:55 AM
OutlawMike's Avatar
99% sure, clogged PCV valve.
It is on the P-side valve cover, under the intake plenum. It blocks up, the crankcase builds pressure, and pushes oil/vapor out the D-side tube, up into the intake flex line that attaches to the throttle body.
Cheap to fix, messy to clean up the air box, and a total pain to get to it.
I would say that the only good way to do it is to pull the plenum, that big aluminum thing on top of your motor that the throttle body is bolted to. You will need to replace the grommet in the valve cover to do it right, and the only way to do that is take the plenum off.
Good luck
Old Aug 15, 2009 | 06:58 AM
nygaard208's Avatar
thank you so much!!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
HRDC0R19
Jul 5, 2015 06:43 PM
