Turbo 4runner 5 spped swap
Hey everyone. I have a 87 turbo 4runner auto of course.
Im looking into doing a 5 speed swap. From the research ive done is it true that the only transmission that will fit it is the r151?
Is that the transmission off the 3.0 v6?
Thanks all
Thanks all
R151 = the turbo 5-speed, R150 = V6 5 speed.
Major differences are the 151 has the bell housing that bolts to a 22R block and the output that bolts to a gear driven t-case. The R150 bellhousing mates up to the V6 block and the t-case is set up for a chain driven case. A W56 transmission would also bolt up, not quite as strong as the R151 but more common:
http://www.marlincrawler.com/htm/tra...ansmission.htm
Should swap over, would need the transmission and transfer case (R151F or W56 - no difference). May need the connector and wiring for the 4WD switch in the t-case and the reverse switch in the transmission.
