Trying to locate a vacuum siwtch for a 1993 22re
Old Dec 21, 2013 | 02:54 PM
93 Toyota 4x4's Avatar
I'm trying to locate a vacuum switch that fits on top of the valve cover. It fits on the cam cover plate. On the plate are three switches. I need the blue one which has three vacuum hoses and a plug in electrical connection. The number on the switch is 90910 12085.
Does anyone have one they are willing to part with??
Old Dec 21, 2013 | 03:41 PM
YotaWoRx's Avatar
What is wrong with yours?
Old Dec 21, 2013 | 03:52 PM
somehow when replacing the head gasket I broke one of the vacuum plugs on it. trying to locate a used one, as the dealer wanted an arm and a leg....and no Vaseline either.
Old Dec 21, 2013 | 06:42 PM
YotaWoRx's Avatar
I've seen people fix the nipples on those with aluminum tubing found at hobby stores or maybe Home Depot, and some epoxy
Old Dec 23, 2013 | 04:15 PM
found the other plastic end and will try to use epoxy. Also found one from an 89. it's a little different but will; work till I get the original one epoxied up...hopefully it will hold.
Old Dec 23, 2013 | 06:14 PM
lobukbuild's Avatar
did you check with a dealer for a new one? theyre probally cheaper than you think. or try a junk yard?
Old Dec 23, 2013 | 08:29 PM
dealer wanted $120....lol, got a member here for less.
88sasturbotoy
Jan 30, 2026 01:57 PM
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
kcaudill
Jul 20, 2015 12:06 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
