Tryin to get my doors off
Old Jun 10, 2007 | 07:32 PM
rooney's Avatar
I'm try to get the drivers door off of my 86 4runner right now and it's a bit difficult. My windows are manual so all i have are those 4 bolts. The top 3 came of with some heavy persuasion and the tights wrench i could find. The bottom one though, is not coming off. I'm worried i'm beginning to warp the edges of the bolt and then it will never come off, so i came here. I think i have the door propped up correctly so that it's not it's own gravity holding the bolt in. Should i use the straw on the WD-40 and let it soak for a while? i don't tihnk these doors have ever come off, personally. any suggestions?
PS. i think i've seen something here about this, but has anyone just cut the actual hinge bolt, and replaced it with a nut and bolt that can easily by undone? it seems like that'd be soooo much easier. thanks
Old Jun 10, 2007 | 07:36 PM
Tacoma Dude's Avatar
I would put the other bolts back in and then try to loosen that last one. It may help you to pre-treat it with some PB Blaster.
Lesson to learn here is loosen everything before things actually come off.
bigtrucknwheels's Avatar
yeah, people around here have done it, i don't even think you need to do a thread search, should be on the first thread page. anyways, keep spraying that with WD-40. the more the better, not necessarily in ounces, but in repeat attacks of the rust. also double check the door balance. i recently pulled a door off a Nissan Sentra i sold and if its out of balance even the slightest, you'll never get it.
Old Jun 10, 2007 | 07:49 PM
Last I heard, WD-40 isn't enough of a penetrant to work on something like this. If you are serious about what you are doing here (generally with your truck) then this will not be your last time encountering a stubborn part rusted shut/down. Invest in a can of PB Blaster and you'll see why everyone raves about it.
Old Jun 10, 2007 | 07:53 PM
hmmwv15's Avatar
PB works for me! Just spray, let sit a few, and attempt again. If it still doesn't move, refer to step one!
Old Apr 11, 2008 | 06:57 PM
country_wheeler's Avatar
I'm having the exact same problem. The lower drivers side hinge is shot (excessive play) and while trying to adjust I found that both bolts on the top hinge (the hinge to door bolts) loosened nicely and the top bolt on the bottom hinge but the bottom bolt unthreads about 3/4 turn and then binds up again.
I need to get it off to replace the hinges. I've already tried soaking it in wd40. I guess I'll keep playing with it for now, maybe try this PB blaster stuff.
Old Apr 11, 2008 | 07:05 PM
Hayes's Avatar
put all the bolts back on and remove the bottom one first. loosen them all at the same time, though...little by little will be best.
Old Apr 11, 2008 | 07:09 PM
stupid_mud_gremlins's Avatar
How rusted is it? If you expect the threads are rusty, try tightening it slightly first, or give the bolt head a good smack with a punch/socket extension and hammer and try loosening it again.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
JamesDINAN
Sep 22, 2015 05:37 AM
