truck wont start!! help!
Old Oct 26, 2010 | 12:24 PM
INFINITY's Avatar
i would check the ign + wire that runs to the starter from the ignition switch (the small wire attached to the starter). i have seen them corrode and slowly loose the ability to make continuity to the starter solenoid to start the cranking.
Old Oct 26, 2010 | 12:33 PM
cEElint's Avatar
hmm.. i'll check it out.. i cleaned up the contacts from the battery to the starter w/ some sandpaper and still nothing
Old Nov 2, 2010 | 04:18 PM
cEElint's Avatar
so you guys think my problem lies within the starter?? i really need to get it going, i have a bunch of crap on the side of the house that needs to be hauled off
Old Nov 2, 2010 | 04:33 PM
1990yota-pickup's Avatar
use some jumper cables for extra groundins contacts... you would be supprised..
pull the starter and take it apart those starter are verry simple to rebuild and diagnose...
you need to put a multimeter on your soleniod wire on starter ans see if your are get 12vdc to the starter solenoid wire.. if not. BACK track to the starter relay and the ignition switch..
Old Nov 3, 2010 | 08:42 AM
  #25
cEElint's Avatar
alright.. time to find a multimeter.. lol
Old Nov 3, 2010 | 09:11 AM
  #26
Bojangles's Avatar
Mine did the same thing on my 87 yota.
Its the starter.
Might as well bite the bullet and get a new one.
Did you have a warranty on the old starter? It should still be under warranty, and that means FREE!
Best word ever.
Old Nov 4, 2010 | 03:56 PM
  #27
pick up crafstman multimeter from sears... it does everything those fancy fluke ones do, and its only 35 bucks or so, not like 175-299 dollars...
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
