Old Mar 11, 2016, 03:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
truck wont go into gear while running?
Old Jul 7, 2017 | 11:13 AM
  #41
ZeusKitty's Avatar
Originally Posted by RJR
First thing to check is if the master cylinder reservoir is full of fluid. Could be nothing more than low fluid if you haven't checked in a while (or ever).
Agreed!
When the reservoir was still full, I was thinking internal leaking between the cups not allowing pressure to build to the slave, since there were no outward signs of leaking. I couldn't figure out why the clutch start switch wouldn't start the truck with the pedal going to the floor. The clutch itself was working fine. Once muscling into gear, it drove just fine, it was the actual shifting that was the problem.
Edit: It just struck me now... Internal cup failure is pretty much a brake master issue, as the CMC only has one reservoir. DOH!
Once I got home, I pushed the pedal while watching. I noticed that the tab on the pedal was so far out of alignment that it wasn't even touching the switch. It was a relief to know what the problem was, but I'm not looking forward to the R&R.
As I stated before, I'm grateful for the ones that have the experience. A cracked support would have been the last thing I would have been looking for, as it seems to be with most others. ;-)
Last edited by ZeusKitty; Jul 7, 2017 at 11:18 AM. Reason: Suddenly realized how ignorant my original statement was.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Ichneumon
Sep 27, 2015 04:21 PM
ACZR
Jun 23, 2015 07:55 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
