truck hesitates and back fires 22re
Old May 18, 2008 | 08:09 AM
mudtoy1986's Avatar
hey guys just got my engine in after a month and now it hesitates and back fires
im shure people have asked these questions before any sugestions as to where i can get some ideas as to what i did wrong
well the engine i used was a 22r and my truck is a 90 22re have hooked up all sencors and grounds only thing i can think is timing
Old May 18, 2008 | 08:22 AM
abecedarian's Avatar
It sounds like you're running lean off idle.
Not 100% sure if this would cause your problem but the 20r is ~2200cc and the 22R/RE is ~2400 cc's. Considering the EFI on the 90 would be programmed to deliver fuel at a rate for the larger engine, there is a large possibility that your problem is there. You would have to at least recalibrate the air-fuel meter for the lesser air-flow requirements of the 20r- probably relieve some of the tension on the spring inside the afm so it opens more easily.
And definitely make sure the timing is set properly.
Old May 18, 2008 | 08:55 AM
mudtoy1986's Avatar
thanks for the info man but i used a 22r not a 20r but ill check the afm to make shure
Old May 18, 2008 | 09:14 AM
doh! sorry. check the valve adjustment, vacuum leaks, TPS too just to be sure.
Old May 18, 2008 | 01:46 PM
mudtoy1986's Avatar
ok thanks man i know my tps is bad cause it revs up and down
Old May 18, 2008 | 02:09 PM
fluctuating engine speeds does not necessarily mean a bad TPS.
It could be a vacuum leak, O2 sensor, coolant temp sensor...
Old May 18, 2008 | 02:19 PM
mudtoy1986's Avatar
hmm never thought of that ill look in to it
Old May 18, 2008 | 02:57 PM
ahickman's Avatar
oscillating engine speeds = air in the coolant line ?
Ichneumon
Sep 27, 2015 04:21 PM
serenity03k64
Jun 27, 2015 07:59 AM
ibayne
Jun 26, 2015 06:30 AM
93handmedown
Jun 19, 2015 06:26 PM
