Truck dying when warm and brakes applied... And foil and copper around exhaust??
Old Nov 16, 2009 | 04:21 PM
Jeremy11's Avatar
I have a 1990 4runner 3.0 V6 and when its cold it runs just fine.
BUT: When it warms up and i've been driving it a little while, is when the problem starts. When i come to a STOP sign or STOP light my RPM's drop down to about 500 and stay for a few seconds then quickly drop to about 100-200 and shoot back up to about 500. (<-- Takes about a second to do this) After it does that a couple times it will just give up and die. Then i have to start it up and give it some gas to stay on. So what i do is when coming up to a STOP i put the truck in Neutral that way it stays at about 800 Rpm's. And then once the light changes i put it in drive and go on my way. Could this be a vacuum leak??? I have 2 hoses that come from the bottom of my power steering up and arent connected to nothing because i dont know where to put them. Here is a pik...
PS: Any idea what this copper tubing is around my exhaust pipe???
Is this foil??? Or a patch???
Any help is appreciated
Old Nov 16, 2009 | 05:11 PM
Tracey98277's Avatar
WOW. i've never seen a tin foil job like that. someone really did a number on that exaust. but those two vacuum lines do connect to the intake chamber, torwards the firewall side there are two vacuum fittings that are forked, one large and one small on each, the PS lines go on the smaller fittings. one fitting is acctually on the chamber its self and the other one appears to go underneath it.
Old Nov 16, 2009 | 05:18 PM
Jeremy11's Avatar
Thanks I will take a look at that right now.
Old Nov 16, 2009 | 05:28 PM
Elton's Avatar
wow what in the hell is that
Old Nov 16, 2009 | 05:39 PM
peow130's Avatar
Man thats totally custom.
What brand? Is that a flowmaster?
xD
Anyways, on a serious note that is definitely not supposed to be there.
Old Nov 16, 2009 | 05:49 PM
i know right? i've never seen anything like that before.
Old Nov 16, 2009 | 05:59 PM
where do those copper tubes go? up the firewall? looking at that picture i'm starting to think it's someone's attempt at "fixing" the heater core or something.
Old Nov 16, 2009 | 06:11 PM
Jeremy11's Avatar
the copper tubes go to nothing. thy are just there. and i dont think its flowmasters. it was like that when i bought the truck. i was gonna take it off but it might be a "patch" for a hole in my exhaust..
Old Nov 16, 2009 | 06:12 PM
peow130's Avatar
I'd pull that foil off if i were you, and then fix your exhaust..
Old Nov 16, 2009 | 06:13 PM
Jeremy11's Avatar
well right now i have nothing to fix my exhaust. do i leave it on there? and the copper tubing take it off??
Old Nov 16, 2009 | 06:27 PM
just leave it for now but definately look into getting that fixed. were you able to figure out the vacuum leak?
Old Nov 16, 2009 | 06:29 PM
peow130's Avatar
Heres a ghetto fix..
Two hose clamps, and some thin gauge stainless steel ...
Cut the stainless with some tin-snips, or whatever, curl it around the xhaust, and clamp it on..
Old Nov 16, 2009 | 06:33 PM
yeah thats acctually a good fix. hey peow, got any pics of that '78 camaro up?
Old Nov 16, 2009 | 06:34 PM
Jeremy11's Avatar
the vacuum leak im pretty sure are those 2 hoses. im thinking. i also just found out that one of my fuel injectors is leaking. gotta get that replaced soon before i start a fire:/ Dont want that
Old Nov 16, 2009 | 06:42 PM
yeah but remember the leak isn't comming from the hoses but the fittings they go to, i can't find anything in the FSM about those hoses. i put a vacuum gauge on mine and when i had stock cams the vacuum pressure at idle was 18-20 hg.in.
Old Nov 16, 2009 | 06:49 PM
Jeremy11's Avatar
nevermind. it cant be those hoses. it sounds like its under my TB because the fittings that the hoses go to are capped off by another hose being "u"'d to the inserts. i just have to get new hoses and connect them. as for the vacuum leak i gotta look harder when i replace that injector or those injectors..
Old Nov 16, 2009 | 06:50 PM
and yeah leaky injectors suck, what you should do if you can is download the factory service manual, get new injector o-rings and intake gaskets, and just do a quick upper manifold/injector job on it. but sometimes you can rotate an injector a little or wiggle it back and forth and it will buy you some time, but sometimes it breaks the o-ring so you're taking a risk. i hope you get everything patched up. you gotta love our smilies on this forum. priceless...
Old Nov 16, 2009 | 06:55 PM
Jeremy11's Avatar
yes they do. i had half a tank of gas yesterday went about for a 30 minute drive. now im barely making it in my driveway,, i just replaced an injector o ring this past weekend. im thinking the mechanic that worked on it didnt see the other one leaking. Time to find a new one. :/ and the smileys are pretty intense..
thhanks for all your help
Old Nov 16, 2009 | 06:59 PM
peow130's Avatar
just put it in storage yesterday :/
91toybeater
Dec 27, 2015 07:46 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
marcusSRG
Jun 27, 2015 07:13 AM
slider417
Jun 22, 2015 10:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
