Truck 'bucks' when cold...
Old Dec 23, 2011 | 05:15 AM
chnkymnky's Avatar
But runs fine once warmed up.
The plugs are new. I can replace the wires and cap and rotor, but I don't think that's it.
Nor do I think it's vacuum.
I'm actually at a loss - is there something that would cause a truck to buck when cold in 2nd and 3rd (and a bit in 4th; can't tell about 1st b/c not in 1st long enough to tell...), but run fine when warm?
Throttle body sensor perhaps?
Thoughts?
Thanks!
Old Dec 23, 2011 | 06:49 AM
tj884Rdlx's Avatar
cold start injector?
Old Dec 23, 2011 | 07:28 AM
dubbsbetty's Avatar
Have you checked the actual timing, my 86' 22RE was doing it as well in first and second at higher rpm. Sometimes the the engines just get out of it's torque range for the selected gear, how bad is it bucking, I think for a while there mine did it because of a brand new engine install and my fuel pump wasn't getting it adequate pressure, took it n it's maiden voyage to the wilderness and opened it up a bit, truck runs great now. NE ways, try your fuel pressure
Team420
Jan 12, 2021 04:57 PM
Weidle
Jan 21, 2019 05:39 AM
MadMax48
Jul 3, 2015 08:26 AM
Gamble_STi
Jul 1, 2015 12:51 PM
rwh2toyota
13
Jun 27, 2015 05:39 PM
