trouble with headlights
I have a 86 4runner that I just got. The low beams work, but when i switch to hi beams there is nothing at all. Is this a fuse problem, switch? If it is. where is it located.
New at this toyota thing, if it was a old chevy I would have fixed it already.
thanks for any help.
its the headlight switch. I have the same exact problem on my 87 4Runner. 4Crawler has a cheap fix on his webpage I believe, but you can also get the assembly pretty cheap from a wrecking yard. Nix99 perhaps
